Galfer brake lines
Has liked: 510 times
Galfer brake lines
I just received my order of Galfer braided brake lines, and the packaging says they're for '87-'93 Voyager XII. Is there a difference from '94 up? When I ordered them I specified they're for a 2000.
Been liked: 83 times
Re: Galfer brake lines
Not sure, but all 12s are the same. The kit you bought will be different but should fit.
This is why you should have ordered them from me. The brake lines I sell will fit all Voyager1200 and are exect replacement.
cushman eagle (Fri May 14, 2021 8:49 pm)
HMB Don wrote: Thu May 13, 2021 7:31 pm Not sure, but all 12s are the same. The kit you bought will be different but should fit.
I know, Don, I should've bought them from you, but these were half the price. My new progressive rear shocks cost half as much as the bike did!
Was that for all lines? Clutch line and rear brake line
HMB Don wrote: Sat May 15, 2021 8:14 pm Was that for all lines? Clutch line and rear brake line
Front and rear brake lines. No clutch line.
You'll love them when they're installed
Barry (Sun May 16, 2021 8:31 pm)
Jeff Gordon
Current bike(s): 92 Voyager, 95 Voyager, FJR1300
Post by Jeff Gordon »
Don, what is included with your kits.....I need brake lines and a clutch line would be good as well.
HMB Don wrote: Sun May 16, 2021 4:49 pm You'll love them when they're installed
I believe it. Everything I've done to this bike has been a huge improvement - it was a poor, neglected, abused $800 bike. She is coming along very, very nicely.
So these braided lines are good for life? No need to periodically change?
triton28 (Tue May 18, 2021 5:15 am)
The lines I sale are the five line kit. Front brake lines (3) two to the calipers and one from the master cylinder to the Junction block. The 4th clutch line and 5th rear brake line. Also included is all crush washers and banjo bolts.
This kit is the exact replacement of the OEM rubber brake lines.
chicagorandy
Has liked: 9 times
Been liked: 14 times
Post by chicagorandy »
I can't recommend Don's stainless line kits enough. VERY complete, fit like a glove and are relatively simple to install. I do also recommend getting a set of "speed bleeders" to make bleeding those lines also a super-simple and quick process.
Don's after-sale customer service and help are fantastic. A great guy to deal with.
T10gator
6
Current bike(s): 2000 Kawasaki Voyager ZG 1200
Has liked: 8 times
Post by T10gator »
HMB Don wrote: Mon May 17, 2021 7:01 pm The lines I sale are the five line kit. Front brake lines (3) two to the calipers and one from the master cylinder to the Junction block. The 4th clutch line and 5th rear brake line. Also included is all crush washers and banjo bolts.
How do I order a set for my 2000 Voyager? And how much ? T10gator wants to know.
T10 gator
Price is $225.00 plus shipping
To order just send me a check including shipping in USD. Shipping in the US is $11.00
My address is 1737 McCorkle Cir., Colfax, NC 27235
Has liked: 243 times
Been liked: 632 times
I'm writing this from memory -- I've slept a few times since I upgraded these hydraulic lines.
I also recommend this upgrade. But I want to mention that the slave clutch banjo was different from what presumably was stock on my bike. Still fit, but not quite as well as stock. This might be because I also switched my bike from floorboards to pegs, which changed some stuff down there.
In any case, it works fine, after very little puzzlement.
