Starter won't sop starting.
Zoss724
4
Current bike(s): 2010 Voyager 1700 ABS (VN1700B)
Post by Zoss724 »
Greetings.
I'm looking for some assistance, advice, insight.
Ok before I get to far. 2010 Voyager. 46k.
Several month ago I had an issue were the bike just would not start. Backed it out of the garage, turned the key - nothing. I had to the power gauges and the radio came on. No crank. No click. No nothing.
I went through the service manual and I diagnosed it to be the starter solenoid (that was my best guess). eBay to the rescue. A few days later all was well; for a month or so.
One day I'm out riding, we made a few stops. Upon mounting my steed, I stated that I wanted to go just down the road a piece to the filling station to top off. As I rode I noticed a "different" noise in the neighborhood of my right foot. Lucky for me It was only a couple hundred yards to the gas station. When I pulled to a stop and turn the motor off, well tried to, the motor continued to run. More descriptively the starter continued to try to and was succeeding in turning the motor over. The key was off, kill switch was in the off position and the kick stand was down, but the motor was still turning over. I proceeded to take off the seat and battery cover and pulled the starter solenoid fuse (30 amp). The starter kept running. I disconnected the battery and then it stopped. Next door was an auto parts store. I purchased some electrical contact cleaner. Sprayed the switched and all the contact points that I could find. After what I am going to call the cool down period, all was well again. I wrote this off to sticky/corroded contact point in the starter button.
Yesterday (a couple of months later) I had the same thing happen again. I just disconnected the battery. Now I asking for help.
OK what would keep the starter running?
The starter button being pushed? Or sticking...
Maybe a "stuck" starter solenoid? Cheap eBay clone?
Any insight?
Very confused
:hmm:
Thankx in advance
Chris Z
Has liked: 240 times
Been liked: 624 times
Re: Starter won't sop starting.
<Deleted -- belatedly convinced myself that I didn't really know.>
Has liked: 500 times
Been liked: 448 times
Sounds like it might be time for a new starter if you replaced the solenoid.
1977 Com-Pac 16 "Hesperus"
Has liked: 116 times
A couple of things come to mind: 1) the starter button is in fact sticking and/or 2) the solenoid is sticking.
However you stated that with the starter fuse removed the starter still continued to engage which leads me to suspect the solenoid itself as the fuse removed should have interrupted the power through the starter button i would think.
I know you installed an eBay solenoid and all seemed OK for a time but the fact that with the battery cable disconnected the problem stops points, in my mind at least, to a solenoid being stuck.
One thing you can do to eliminate the button as the culprit would be to somehow have the freewheeling starter do it again and disconnect the small gauge wires to the solenoid and if the problem stops then you will know it is the button. If the free wheeling starter continues to rotate with the small gauge wires removed then it is the solenoid.
These are just best guesses as the 1700 has a greater number of small gauge control wires than the 1200 which I am more familiar with but in theory once the button is no longer engaged the solenoid should stop supplying power to the starter motor.
Electrical problems are sometimes so frustrating.
Zoss724
4
Re: Starter won't stop starting.
Post by Zoss724 »
Thanks all.
