Computer code on 1985 Voyager 1300
steeltoe
Current bike(s): 1985 Kawasaki Voyager 1300
Post by steeltoe »
I have a 1985 Voyager 1300. Does anyone know how to read codes on the computer? Mine is flashing one long and three short green lights. I can start the bike when it is cold, but if I shut it off, it will not restart when hot. Any thoughts or help?
Me Again
Been liked: 257 times
Re: Computer code on 1985 Voyager 1300
Post by Me Again »
One long three short equals engine temp sensor.
addonii
Post by addonii »
Looks like you need to get your hands on a manual so you can go through the fuel injection.
Just a few more codes I'll pass on and it may be of help to you.
Also try un-plugging and re-pugging in all related connectors to clear some of the corrosion from the connectors.
Self-Diagnosis, and Trouble Codes
Item Criteria Arrangement of Pulses Action
Throttle Sensor | Open or Short | 1 long 1 short | Perform "Throttle Opening Angle Signal Test".
Air Temperature Sensor | Open or Short | 1 long 2 short | Perform Air Temperature Signal Test".
Engine Temperature | Open or Short | 1 long 3 short | Perform "Engine Temperature Signal Test".
Atmospheric Pressure Sensor | Open or Short | 2 long 1 short | Replace control unit.
Starter Switch | Continues on after engine starts |2 long 2 short | Perform "Starter Signal Test', and Inspect starter switch for damage.
Ignition Pulse |No ignition pulses are transmitted to control unit when cranking engine. | 2 long 3 short | Perform "Engine Speed Signal Test. and inspect ignition system damage.
CPU Memory | Memories in CPU do not operate property. 3 long 1 short Replace control unit.
Me Again
Post by Me Again »
one of the best resources for the 1300 Voyager is http://autos.groups.yahoo.com/group/1300Voyager/.
join that group ,go to the links section .Find and download the KZ1300 base manual,and the ZN 1300 supplement manual and the trouble shooting manual.
Members of that site can give descriptions on checking ,replacing and/or bypassing most any type of problem you can have on the 1300.
Good luck
