where is cb radio located????
aace
Current bike(s): 92 voyager 82 virago
Post by aace »
is the cb radio internal???
Tonyvdb
1996 Voyager (Just sold)
1981 GPZ 550 (Previous bike)
Re: where is cb radio located????
Post by Tonyvdb »
The main CB modual is located behind the left upper fairing if it is installed on the voyager. It attaches to the radio as well.
1981 Kawasaki GPZ550 (sold)
Tonyvdb
Post by Tonyvdb »
I should have said When sitting on bike it on the left side
aace
Post by aace »
so the cb is separate from the clarion amfm cassette deck. where can I purchase a compatible cb for a 92 voyager?
Tonyvdb
Post by Tonyvdb »
Yes, ebay is a good place to look for parts for the voyagers. The cb is the same for all 1200s no matter what year if I am correct.
Put a wanted in the classifieds, there was someone at the Rally that had one for sale, not sure if he sold it.
They come up on Ebay once and a wile not vary often anymore, expect to pay $300-$400 for a used one.
also might want to check with Carl Leo :thmup:
voyager55
Current bike(s): 2003 1200
Post by voyager55 »
Be sure you really need one. You'll pay a fortune for a cb that should cost around $85
Also look into putting a car cb on the bike if you really need one
suzib6sw
Tourer
Tourer
Post by suzib6sw »
The full CB kit comprises of..
The Main silver module that bolts under the left glove pocket under the left fairing.
The Control unit that sits by your left knee when sat on the bike.
A filter that bolts to the side of the radio that the handlebar controls and groundset cables plug into to help reduce ignition and alternator whine.
A filter that plugs inline with the radiator cooling fan to reduce motor interference.
An Antenna bracket for the left side of the bike,
The Centrally loaded antenna and cable.
Add on switch blocks (Channel change and PTT switches) that bolt on top of the left handlebar controls and into the rear passenger controls and their associated harnesses.
Optional extras were the headset Y Cable and of course, headsets.
Originally, the kit was about $900 new with the radio at $1768 new..
If you decide on using one, then make sure the control box (left knee) not allowed to get wet. While I can get most of the components still in the main box, the LCD decoder/Driver chip and of course, the LCD display have no stocks anywhere.
J&M make a nice add on CB with handlebar controls for the goldwing which will also shoehorn onto a voyager BUT they too are circa $400-$500
The '96 "Anniversary edition" voyager seems to be a "special case" depending on when it was built during that year. From what I can gather and from rumours, I believe it came with the CB as a stock item. some models were equipped with just one antenna, the CB loaded one, and a splitter that allowed the Radio and CB to use the same antenna..
I stand to be corrected of course on that one..
Cheers,,.
Pete
Pete
1986 Voyager XII
ghostler
Has liked: 3 times
Been liked: 10 times
Post by ghostler »
I found tips on installing an aftermarket CB radio with interface to the Clarion from:
http://www.tinlin.net/motorcycle/parts.html#radio
I downloaded the PDF link for the wiring diagram for the interface. Amazingly, I was still able to get the aftermarket push-to-talk switch, rider and passenger wiring harness and headsets as specified. I tile printed and now have the wiring diagram plan. It is not the easiest to read, as it is done is bus style wiring instead of a true electronic schematic. Found sources for the various DIN connectors. Forget Radio Shack, they have eliminated a lot of the electronic parts over the years.
This will be a Fall wiring project for me. Now I'm installing heated grips, alarm and trailer harness wiring. I bought a new Midland CB-1 radio off E-Bay for around $35, trucker 3 feet CB mirror antenna with bracket for under $15 off Amazon.com. Will fabricate my own CB antenna bracket to bolt under the trunk location from a section of 1/2 inch square pipe I have. CB radio will mount in the cassette tape storage compartment on the left. By opening the compartment door (or leaving open) will allow access to the CB radio while on the road, but allow security and weatherproofing by locking when parked or during rain.
If all goes well, I'll post on how my installation went.
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
suzib6sw wrote: The '96 "Anniversary edition" voyager seems to be a "special case" depending on when it was built during that year. From what I can gather and from rumours, I believe it came with the CB as a stock item. some models were equipped with just one antenna, the CB loaded one, and a splitter that allowed the Radio and CB to use the same antenna..
Cheers,,.
Pete
From what I understand in 1996 (or whatever year the price of the Voyager went up a lot) the voyager was to have the CB standard but it was dealer installed and a lot of dealers did not put them in.
The single antenna I herd about but don't know when they did that.
ghostler
Has liked: 3 times
Post by ghostler »
chevyman1 wrote:From what I understand in 1996 (or whatever year the price of the Voyager went up a lot) the voyager was to have the CB standard but it was dealer installed and a lot of dealers did not put them in. The single antenna I heard about but don't know when they did that.
A single antenna can be used with a splitter such as
http://www.wearecb.com/am-fm-cb-antenna-splitter.html
One replaces their AM/FM antenna with a CB one then uses this splitter to merge the signal onto one antenna. I don't know if this particular splitter will on the Clarion radio or not.
George Hostler
Clovis, NM, US
1971 Honda CB100
suzib6sw
Tourer
Tourer
Post by suzib6sw »
Certainly should work, however, as with all splitters, overall performance may be affected. Having said that, you probably wouldn't notice.. :-)
Pete
1986 Voyager XII
ghostler
Has liked: 3 times
Post by ghostler »
suzib6sw wrote:Certainly should work, however, as with all splitters, overall performance may be affected. Having said that, you probably wouldn't notice.. :-)
You bring up an interesting point. I would want performance to be as optimal as expected given limitations of the Midland CB-1 unit, portions I've traveled solo through rural areas with no cell phone service. Only means of communication is CB. Besides, I looked at the Clarion AM/FM antenna and mount, it won't handle a CB antenna with standard electrical connectors. That leaves me with constructing my own antenna mount system.
George Hostler
Clovis, NM, US
1971 Honda CB100
ghostler wrote: I looked at the Clarion AM/FM antenna and mount, it won't handle a CB antenna with standard electrical connectors. That leaves me with constructing my own antenna mount system.
I have an extra factory CB antenna and mount, if you are interested PM me
Kevin B in Illinois
2009 Kawasaki Vulcan Voyager
1969 Kawasaki Sidewinder 250
1965 Kawasaki F2TR 175
2006 Suzuki DL1000
Post by Kevin B in Illinois »
1996 Anniversary Edition came with a CB that was installed by the dealer as a bonus for the Anniversary Edition. Many dealers did not install these , even though it was supposed to come with it on the 1996. Rick Alden , former longtime board member and former service manager for Steir's Kawasaki in Elgin during this time confirmed this when they came out. Contact Ricky Breit of MO KAN voyagers for a CB, he had two at the Rally for Sale and still has one that I know of.
KB
IPVMC
