Brake Pad spring question
Bulldogx11
Current bike(s): 94 KAWASAKI VOYAGER X11
Post by Bulldogx11 »
Hi, did my brake pads ,on front the lever was spongy. so I heard on hear that it was probably the spring was up in front of the caliper piston ,and it was so I fixed it and the lever is good now. if I push down the spring thing to get it to clear the piston the outer pad sat on the bump of the spring is that ok ? does anyone have a video on how it goes together ? after riding alittle my back brake makes noise -chatter when applied could that be the spring also? thanks for any help
bikerking.biz
1970 Honda CL 350
Re: Brake Pad spring question
Post by bikerking.biz »
Your chattering brakes may be because of this problem.
http://www.amervoyassoc.org/techtipsXII ... g%20Brakes
Biker King
http://www.bikerking.biz
Bulldogx11
Thanks ,I checked the retainer /spring seemed ok ,greased the slides there ok, cleaned the caliper piston worked in and out seemed ok . I used organic pads Still making a little noise ,could it be they just have to break in ? I guess I should try to change the fluid ,do you guys empty the fluid totally or can I just keep adding fluid and bleed it till it comes out clean? thanks for any help
bikerking.biz
1970 Honda CL 350
Bulldogx11 wrote:do you guys empty the fluid totally or can I just keep adding fluid and bleed it till it comes out clean? thanks for any help
I always remove most of the fluid from the reservoir (leave a little above the intake hole so air is not introduced), add fresh, then bleed until it comes out clear at the bleeder. Make sure all the air is out.
Biker King
Bulldogx11
Thanks for your help. I will flush fluid a.s.a.p.
