The new battery on the left check the two spacers under the battery. These were included in the box with the battery. Shorai 3# and old lead acid 16#.
After four years and 99,000 miles, on a 41 degree morning the starter just started my Voyager. So when I got home, I started looking at batteries. I settled on the Shorai battery, this is a feather weight battery. Buyin was a bit high but saving 15 lbs was worth it. Removing the old battery was the normal chore, but when it came time to install the Shorai it was a breeze. At 3 lbs it felt like a paper weight. I also bought the Shorai battery charger that was $72.00 but I'll continue using the Shorai on both the Voyager and the Goldwing trike. I did have to grind both the Shorai battery terms. They were about a 1/8" larger then the Voyager 1700 battery cable ends.
