shorter antenna
wmh9680
Current bike(s): 2002 Kawa Voyager
1996 Yamaha Virago 1100 Special
shorter antenna
Post by wmh9680 »
Has anyone ever put a shorter antenna on the bike. Mine hits everything I have hanging from the rafters in the garage. Also my mute button in front isn't working. The rear is and sometimes when I raise the rear luggage lid it must press something on the rear radio controls and the front controls quit til I play with the rear ones. Is it possible to disc the rear controls. I know sometimes the rear controls cancel out the front if you hit something. Thanks, Mike
vxiirider
Tourer
Tourer
Has liked: 99 times
Been liked: 34 times
Re: shorter antenna
Post by vxiirider »
I have removed the rear passenger control on our "03 and the radio still works just fine. I also cut off about 6" of the antenna and find no difference in radio reception.
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Re: shorter antenna
Post by gearheadfla »
I cut my ant. off at the metal sleave sbout a foot from the tip, still works find and don't hit going in the ole garage.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
wmh9680
Re: shorter antenna
Post by wmh9680 »
How do you remove the passenger control? Thanks, Mike
96desertXII
Re: shorter antenna
Post by 96desertXII »
wmh9680 wrote:How do you remove the passenger control? Thanks, Mike
Just unplug it and remove the mounting screw................everything will still work.
Chuck & Ruthie
1989 FLHS (sold)
2009 FLHTCI (sold)
2005 FLHRI (sold)
2003 FLHTCU (sold)
1978 GL1000 (sold)
1978 CB750K (sold)
1958 FLH (stolen)
chevyman1
Been liked: 16 times
Re: shorter antenna
Post by chevyman1 »
I have one of those 2' rubbery antenna on Teem green and it seems to work just fine
dmwoost
Current bike(s): 1997 Kawasaki Voyager XII
1982 Suzuki GS 850 GL
Re: shorter antenna
Post by dmwoost »
The middle of the FM broadcast band is ~98MHz
and 1/4 wavelength is ~28.5 inches.
wmh9680
Re: shorter antenna
Post by wmh9680 »
what does "The middle of the FM broadcast band is ~98MHz band 1/4 wavelength is ~28.5 inches" mean? I took off the piece after the coupler on the antenna and it seems to work fine. I also unplugged the pass remote.
Any idea why the mute on my front control doesn't work, the rear mute was working before I disc it. Gonna take here out today. Thanks, Mike
suzib6sw
Tourer
Tourer
Re: shorter antenna
Post by suzib6sw »
The Front and rear controls are all in parallel with each other.. So, if your front mute no longer works, your switch is either dirty or you have a wiring fault from that switch to the plug to the radio..
As for the 28.5 ".. That is the 1/4 wave length at about 98Mhz.. so the "optimum" length of the Antenna should be about 28.5" for one of its resonant lengths..
A Full wave antenna for FM is about 10 Feet.. , Half wave is about 5 foot.. etc..
So, if you were to measure up from the base, ,28.5 inches and cut, you would be close to an optimal perfoming antenna for that length..
Having said that, The stock radios , around town will work with a bent wire coathanger..
I work on the radios in the basement of a 1943 house, with aluminium siding and expanded mesh behind the plaster ( In ideal faraday cage more or less) but one Radio test, is to receive FM with nothing more than a screwdriver in the antenna socket..
Am Reception May be affected a little and FM reception distance WILL be affected with a shorter antenna but Thats when the MP3 socket comes into its own ;-) (Blantant plug) !!!
Cheers..
Pete
Pete
dmwoost
Re: shorter antenna
Post by dmwoost »
I had my Radio out earlier this year and had Pete do some up dates and add the MP3 plug.
Made a trip into the Rockies in late June and the MP3 worked great where we had no reception.
The work was very good and the price great. well worth the upgrade.
wmh9680
Re: shorter antenna
Post by wmh9680 »
Thanks, I'll have to measure what I have done (disc at the allen screw connection). Thanks, Mike
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Re: shorter antenna
wmh9680 wrote:Thanks, I'll have to measure what I have done (disc at the allen screw connection). Thanks, Mike
I did mine there too, no problems at all, work just as good before. :thmup:
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
