Highway pegs
Champion Trike
Been liked: 4 times
Re: Highway pegs
Post by hank43 »
Me Again wrote:For those of us who do not have the luxury of a mill in our garage/workshop,a piece of 5/8 water pipe(7/8 OD) and a 1 " chrome towel bar cut to length ,should give strength and a nice finish.
:hmm:
you don't have a mill??
hank
Steve do
Re: Highway pegs
Post by Steve do »
I just got a set of the ones SgtSlag was talking about, They were well made and worked good so far. The short cut is in his post.
Steve do
Re: Highway pegs
Post by Steve do »
Kehoffman, I used the Emgo floorboards, for the brace I got a machine shop to cut a 1" aluminum round stock 22" long down to 7/8" on the ends. I left the center at 19", I had to bend the crash guards just a little in to get them to line up. I put a straight edge on the crash bars to make sure they were lined up, they weren't. Check yours before you get the 19" measurement. Will get a picture for you.
Steve do
Re: Highway pegs
Post by Steve do »
I drilled a hole, tapped it for 5/16" SS bolt. The bar is 1" aluminum round stock, 22" lone cut down to 7/8" on each end, center is 19 " after making sour the crash bars are straight, I had to bend mine a little they where not straight.
Hope this comes out, still learning.
lockwoodjohn
Re: Highway pegs
Post by lockwoodjohn »
Hi everyone,
The OO of the crash bars is 1 inch. If I get 1inch clamps to mount
My Led running lights to the crash bars will they tighten up enough
Or should I get 7/8 clamps?
Thank you, lockwoodjohn
Been liked: 249 times
Re: Highway pegs
The 1" clamps will work fine. That is what I got for my LED's, and there has never been an issue with them being loose. I like my clamps tight, and secure, and that was quite easy to do.
However, if you find them too loose, cut an old rubber inner tube into appropriate sized strips, and insert them inside your clamps. Not only will they fill the small gap, but they will also prevent the metal clamps from marking the bars they clamp around. Did that with mine, no scratches on the bars when I removed the clamps, and everything is right and tight. Cheers!
lockwoodjohn
Re: Highway pegs
Thanks for all the input. I WILL order the one inch clamps for my Led
Running Lights which just came in the mail today. Got them from E. Bay.
Thanks Again,
lockwoodjohn
