Horn Button
- Current bike(s): 2013 Vulcan 1700 Voyager ABS
Horn Button
Hi out there in Voyager Land. Just wondering if anyone else has an issue with the location of the horn button? I've had my '13 1700 since May 2013. It is a great bike and a joy to ride. I have average size hands and I find it to be a pain in the A** to reach the horn if the situation arises, and I live in Los Angeles...So it does!!! I have to totally remove my hand to even reach it.
Any thoughts???
Thanks,
Ralph
Any thoughts???
Thanks,
Ralph
- Current bike(s): 2010 Kawasaki 1700 Voyager
Re: Horn Button
I agree. The position is so bad that for all practical purposes I operate as though I don't even have a horn. If I have the time to look for it I can reach it without removing my hand, but it's quite a stretch. If I try to honk it without watching I usually hit something else by mistake - most often the dimmer switch. In any case, the sound of the stock horn is pretty pathetic.
1975 Goldwing (found a good home for it)
2003 Nomad 1500 (traded for the Voyager)
Re: Horn Button
Agree 100%. Kawasaki has sent me numerous "owner surveys" and I have mentioned it on every one. All they really need to do is swap the horn button and high beam switch. I've just learned to "vocalize" my feelings. And also sneak up on their passenger side and fold in the side mirror!!!
- Current bike(s): 2003 kaw voyager 1200
Re: Horn Button
you might get ran over doing it that wayMarinebiker1700 wrote:Agree 100%. Kawasaki has sent me numerous "owner surveys" and I have mentioned it on every one. All they really need to do is swap the horn button and high beam switch. I've just learned to "vocalize" my feelings. And also sneak up on their passenger side and fold in the side mirror!!!
- Superdave54
- Current bike(s): 2012 Voyager
1980 Goldwing Standard - Location: Bellingham, WA
Re: Horn Button
I find yelling works a lot better. And, it's way more manly sounding than that wimpy little "toot" that comes out of the stock horn.
Doesn't work so good with my helmet visor down. Spit droplets all over the inside, and nobody can hear me.
"Better to be silent and be thought a fool, than to speak and remove all doubt".
Re: Horn Button
Think you've got it tough? My left thumb was amputated mid way between the 1st & 2nd joint, I have a hard enough time with the high-low beam button let alone the horn but it would help a lot if Kawasaki would switch them around.
- NSASarge
- Current bike(s): 2015 CanAm Spyder RTL
2010 Voyager 1700 - Location: Near Yanceyville, NC
- Been liked: 6 times
Re: Horn Button
Has anyone tried to see if the Horn and Hi/Lo headlight buttons can be switched?!? Uh ... swapped, that is.
UPDATE: ... Just looked at them. NOPE. Cannot be switched as the Hi/Lo beam switch is longer than the horn button. At least, not unless you get really creative ... Hmmmm. Gonna have to look at that more closely when I get time. Unfortunately, time is in short supply now.
Ride Safe
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
AAA: 620111405125201
Patriot Guard Rider
Retired US Army MI
Retired Thomas Built Bus
Retired
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
Patriot Guard Rider
Retired US Army MI
Retired
- Current bike(s): Vulcan Voyager
Vstar Silverado - Has liked: 0
Re: Horn Button
It's almost a safety problem. When something bad starts to happen you have to chose between horn and clutch. If your thumb is on the horn you don't have leverage to pull in the clutch. Many dire situations call for both.
- David (N. Alabama)
Re: Horn Button
I only use the horn as a warning. If I am having to avoid a situation, I don't have time to beep the horn.
If I am in traffic with multiple lanes flowing the same direction, I will ride with my thumb poised over the horn button just in case the guy I am passing starts to get close to my lane.
To do that I just rotate my entire hand so I am still touching the grip. No need to remove my hand from the grip to hit the button.
- Current bike(s): 2012 KAWASAKI VOYAGER 1700
Re: Horn Button
Get a good set of loud pipes. Then pull in the clutch and turn the throttle. People seem to respond to that faster than a horn, at least in my experience.
- Current bike(s): 2011 Voyager
Re: Horn Button
that is about the only real complaint I have on these bikes. My former Suzuki C90 had the horn then HiBeam switch in that order.
While on topic of HiBeam, I do miss the pass-flicker HiBeam switch on the front side of the that housing (HiBeam/Horn housing). I not only used it to notify of my getting ready to pass you, but when riding at night, it was a really convenient way to temp turn on HiBeams as I was in middle of a dark curve
