Rear Shock replacement
iowawill
Current bike(s): 1983 vf750c Magna
2002 Voyager12
Post by iowawill »
I just installed new progressive 412s on my '02 and was wondering if anyone could tell me torquing spec on the mounting bolts. Also, progressive included flat washers in the installation hardware but I just used the original hardware..was there some reason to use these flat washers? Also, I see in some recent posts that some have taken off the trunk to do this install, but I was able to slide the frame back far enough to install without removing the trunk. Seemed to go back together ok?
Has liked: 117 times
Re: Rear Shock replacement
22 foot pounds- upper and lower.
The 2 upper mounts use a flat and a lock washer, and the lower LH mount uses
a flat only.
iowawill
2002 Voyager12
Post by iowawill »
Thank you, Dave.
