Handlebar Grip Replacement
- Current bike(s): 1998 Kawasaki Voyager Xii
All,
I am relatively new to the forum but have learned many things from reading the great posts. I bought a 1998 Kawasaki Voyager Xii last summer and decided it is time to do some maintenance and upgrades to my ride. I am trying to replace the handlebar grips on the cycle and the plug at the end of the handlebars will not come out. I tried to use an impact screw driver to loosen the screws. They will not move! Has anyone else had this problem? My next step was to heat the screws but I don't want to mess up the rubber in the ends of the plugs.
Any suggestions would be welcome.
Brad
Brad
- the2knights
- Has liked: 32 times
- Been liked: 8 times
Re: Handlebar Grip Replacement
There is usually a fair amount of threadlock on those that make them a big pain for sure. I know a lot of members recommend several different products and ideas. For me I used a pair of channel locks on the bar ends (with a rag to prevent teeth marks, and turned at the same time as the screw. That got it started and then I could finally back the screws out.
Thanks! I will give that a try and see if I can break it loose! I need to get it done somehow because the grips that are on it hurt my hands after and hour of riding. The gel ones I had on my Concours were good to go for the entire day.
Brad
Brad
- doug of so fla
"Grip Puppies" or as called by some "ShinGrips" good sponge rubber covers for your present grips, last forever. very reasonably priced!!! Shinhopples , Talk with owners direct, Bulldog, or wife, Meesh very best customer service around.
http://www.shop.shinhopples.com/ scroll down left side in alphabetical order to "Shingrips"
I think they will fit right over your old ones with out cutting the old ones off. used by many long distance riders and others. Try um you will like um..
+ 1 .... Soap and water 'um up and slip 'um on.... JM2C
- Current bike(s): 2003 1200
doug of so fla wrote:"Grip Puppies" or as called by some "ShinGrips" good sponge rubber covers for your present grips, last forever. very reasonably priced!!! Shinhopples , Talk with owners direct, Bulldog, or wife, Meesh very best customer service around.
- 823JIM
- Has liked: 6 times
I'll 2nd that. Used them on my Voyager, Loved them.voyager55 wrote:![]()
Jim King
650 Kaw "Glory Days"
Jim King
I guess I should have done additional homework before deciding to cut them off and replace them. With that said I do like the choice of grips that I installed. I used them on my Concours and they are very comfortable grips. They are the gel grips I got from the Motorcycle Superstore.
