Rear speakers it's making me crazy!!!
Voyage 90
Current bike(s): 1990 Voyager
Post by Voyage 90 »
Hello all great group here very informative!!! I'm new to the Voyager. Wondering if someone could tell me how to disassemble the rear speakers. I've got new ones to put in and trying do it without destroying anything.. thanks for your help!!!
sgilbert14
Current bike(s): 1998 Concours 1000
Just purchased a 2000 Kawasaki ZG1200 Voyager XII for the spring
Re: Rear speakers it's making me crazy!!!
Post by sgilbert14 »
I have nothing to add but will be doing the same soon. May I ask what you picked up for speakers? I am going to try to fin 2 way 4" marine speakers for both sets. I hope that is the correct size?
... are you asking how to get the speakers off the chrome trunk mount or how to
disassemble the speakers themselves? TIA
Has liked: 117 times
On the Voyager XII rear speakers the 6 screws that secure the bottom rubber dampers also hold the speakers halves together.
Don't try to undo the FAKE hex drive cap screws on the face of the speaker housing as that will ruin your day.
... and if Ya want to get at the screws holding the speakers to the chrome grill,
it looks like there are 4 bolts that pass thru the trunk lid to take the grill off and
make it easy to get at the speaker mounting screws... haven't done it, but
that's how I'd go after it.. Best to Ya!!!!
Each speaker has three acorn nuts holding each one to the bracket. Remove them and you will see that each one of those is a vibration cushion and each of those is held onto the speaker with 2 Philips screws each. When you remove the Philips you will be able to pull the speakers apart. An open end 10mm wrench will remove the speakers from the bracket. You don't have to remove the bracket from the trunk to remove the speakers. Voyager 80 I posted a 2 part piece you can access which shows taking the speakers apart.
shifterkart26
Current bike(s): 94 ZG1200
Post by shifterkart26 »
Mr Jensee wrote:Each speaker has three acorn nuts holding each one to the bracket. Remove them and you will see that each one of those is a vibration cushion and each of those is held onto the speaker with 3 Philips screws each. When you remove the Philips you will be able to pull the speakers apart. An open end 10mm wrench will remove the speakers from the bracket. You don't have to remove the bracket from the trunk to remove the speakers. Voyager 80 I posted a 2 part piece you can access which shows taking the speakers apart.
Where can I find the 2 part piece showing the rear speaker disassembly process? Thanks
I will do a search and try to get it to post in the active list.
Click here for part #2
viewtopic.php?f=3&t=2123
