Someone had turned it counter clockwise. Thus the Molded part on the lid, could not press down the switch. Took the screw out that holds the switch in. Nothing I could see, but then seen an old mark. Mounted the switch but did not tighten down the screw. Turned the switch 1/4 turn clock wise. Shut the lid and could hear the switch click.
Free fix because someone had taken the switch off I guess? Not sure why they would have turned the switch. But its working now and was free. Best of both worlds there.
With it in this spot switch no works.
Switch in this position it works like new.
