Water pump Leak I think
good day to all I am new here just got a 94 Voyager XII drove it home parked it . Went out this morning and had a big trail of oil coming out the left side saw oil dripping off the bottom bolt oil the oil pump should I replace the whole pump or just the oil seal I will include some pictures any advise is greatly appreciated
- Has liked: 117 times
Re: Water pump Leak I think
If there is NO coolant leaking, and the bike seems to rum at the proper temperature without overheating, then this most likely is just an o-ring and oil seal repair on the water pump. Just to be certain, check above the pump and see if the alternator o-ring is leaking (unlikely but possible).
- Highway Rider (Sun May 24, 2020 4:17 pm) • mrutah12 (Sun May 24, 2020 6:36 pm)
Fixed it
took the pump out found out the oil seal walked out cleaned it all up put my yamabond on the seal put it back in put it all back together started it up and no leaks so far will know more tomorrow when I take it to work but I've had it happen to before on my concurs I'm pretty confident its fixed thank you for the reply's and the advice
- These users liked mrutah12's post:
- Scott-(Altoona, PA) (Thu May 28, 2020 4:28 pm)
outstanding !!!! job well done
- mrutah12 (Thu May 28, 2020 1:08 am) • Scott-(Altoona, PA) (Thu May 28, 2020 4:28 pm)
