.im hoping someone has the knowledge. I'm replacing the frictions in my clutch and wondering, are the last two plates clocked the same or only the last one. the manual doesn't really talk about this for the 03. i know after a certain year they added two extra plates, but in the supplemental they don't say last two or last 1.
also all of my steels are 2.3mm when the manaul says 2 steels should be 2.6mm and the rest 2.3. should i replace per manual? or keep all at 2.3?
clutch assemby
- Has liked: 117 times
Re: clutch assemby
According to the MSM, the A-1 and B-1through B-4 models, (1986 to 1990), used 8 steel plates. The first and last are 2.6mm thick and the remainder are 2.9mm.
The B-5 onwards used 8 steel plates; 7 which are 2.3mm and 1 which is 2.6mm.
All models used the same quantity and thickness of friction discs, that being 9 in number, and only the last friction disc has it's tangs fitted in the shallow U shaped groove of the clutch housing.
In your case, B-17 model, the 2.6mm, last steel plate, may have been replaced by a 2.3mm plate to obtain the correct spring plate free play measurement and you should follow the procedure on page 5-4 of the MSM Supplement to determine why you have all 8 of the plates measuring 2.3mm.
Remember a mm is only .040" so your setup may be alright as is but that is only a guess on my part without doing the spring plate test for free play.
Hope that helps in some way,
Re: clutch assemby
you answered exactly what i needed thank you !!triton28 wrote: ↑Sat Nov 21, 2020 1:19 am According to the MSM, the A-1 and B-1through B-4 models, (1986 to 1990), used 8 steel plates. The first and last are 2.6mm thick and the remainder are 2.9mm.
