I got some black Plastic Weld to fix a crack in the fake tank. I drilled out the edge of the crack, sanded and sawed away the old epoxy "fix" attempted by some PO, laid some vaseline coated tape over the top of the crack, and crammed as much of the Plastic Weld into the crack and drilled hole as I could. Hopefully this will hold.
While I had my fake tank off, I finally found the two frame bolts on the right side that always come loose and lo, they were both finger tight. The top one was easy to tighten up, but the bottom one was a real pain to do without taking the fairing off. Tonight wasn't the night the for the fairing teardown I plan to do sometime - but I got the bolt tightened. That's bound to help stiffen up the ride even more. I tried running the forks without air (Progressive springs installed), but they were pretty bouncy and deceleration wobble was pretty noticeable so I put in about 5 PSI. I imagine the frame bolts being loose could certainly cause some wobble when the front takes more load while coasting. The front fork oil was added when the friend I bought the bike from put the Progressive forks in. He actually had the Kawasaki dealership do the job for him, too, and the manual says replace the fork oil roughly every 19k miles so I should have a lot of life left in that oil.
It feels good to be working on a bike again
