Front fork oil
- Current bike(s): 94 KAWASAKI VOYAGER X11
Front fork oil
Hi yes i have searched this out and i kno when you install progressive springs that the air gap is suppose to be 145mm /5.7 inches .. Fill with 10 wt and smaller air gap means more oil ,but i cant find the amount of oil each forks take?? Do i need more than a qt ?
- Has liked: 893 times
- Been liked: 315 times
Re: Front fork oil
Hi,Bulldogx11,The service manual calls for 391 cc per side,which is less than a qt.total.
So you should be good with only one quart,unless you spill some
been there ,done that,especially when I change engine oil,as I often overfill the funnel
