Changing throttle cable 83 1300
grumpy72
99 shadow 1100
93 voyager 1200
Been liked: 15 times
Post by grumpy72 »
When i turn the handgrip i see one thing turning. But the handle doesnt snap back. I heard there are 2 cables. One push one pull.finding one aftermarket is near impossible.bike bandit says unavailable.kz enterprises says the same. I dont want to order from china and get the wrong one. Also do i remove the gas tank to do it? And several wires and console have to be unplugged? I dont get much in the form of answers so please. Respond. I appreciate it.
These users liked grumpy72's post:
Van Voyager (Mon Apr 25, 2022 6:48 pm)
Me Again
Been liked: 273 times
Re: Changing throttle cable 83 1300
Post by Me Again »
You are correct. the tank must come off. I hope it is not full as it weighs a ton.
You can find a PDF service manual here.
https://www.kz1300.com/index.php/home
Van Voyager
Has liked: 51 times
Been liked: 44 times
Post by Van Voyager »
grumpy72 wrote: Sat Apr 23, 2022 9:29 am ...finding one aftermarket is near impossible.bike bandit says unavailable.kz enterprises says the same.
eBay.
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
Well got the missing hose connection figured out.supposedly will het one throttle cable tomorrow.2 cables, one in front is for deccelerate, makes throttle snap back i think.thats the one i ordered per a tip from someone here. If it comes i might get the bike running tomorrow.
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
One cable, the rear one, closest to the tailight works. The other one in front of it does nothi ng.turning the handgrip makes it move slighly.it sreems slack.and it disappears down deep.how in the world do you get down there to put it in place?
Me Again
Post by Me Again »
grumpy72 wrote: Tue May 10, 2022 12:33 am One cable, the rear one, closest to the tailight works. The other one in front of it does nothi ng.turning the handgrip makes it move slighly.it sreems slack.and it disappears down deep.how in the world do you get down there to put it in place?
Get the throttle wide open. Use a screwdriver to wedge it so it stays that way. Using long pliers and skinny fingers you should be able to reach in from the side and hook the cable end in the slot.it should be accessible just under the idle adjust screw. work backwards from there until you get the rest of the cable in the proper slots and snug them up.
I did this in the mid 90s putting in an auto cruise control when my fingers worked a whole lot better, and it was still a couple hours of swearing to get it all attached.
cushman eagle (Tue May 10, 2022 10:37 pm)
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
Thank you times 10,000
