Oil change
Bubba717
1
Current bike(s): 2002 kawasaki voyager zg1200
Oil change
Post by Bubba717 »
I need to do an oil change on an 02 voyager that I’ve had for alittle while now, just wanted to see what oil is best to run in it?
Has liked: 240 times
Been liked: 624 times
Re: Oil change
You'll quickly find the very best oil for your XII by searching this site for "favorite oil". There are a dozen or so.
Stew (Sun Mar 17, 2024 10:41 pm)
Has liked: 891 times
Been liked: 314 times
Re: Oil change
Hello, Bubba717,I have been running Shell Rotella T6 5W40 in my '99 for the past 14 years and 90,000 miles except for about a year it was not available :thmup:
I started running that in my GS1100GK,because of oil beakdown due to heat,and never went away from it. :hmm:
Conrad
89 yamaha venture royale
Has liked: 27 times
Been liked: 62 times
Re: Oil change
Post by Conrad »
cushman eagle wrote: Mon Mar 18, 2024 12:00 am Hello, Bubba717,I have been running Shell Rotella T6 5W40 in my '99 for the past 14 years and 90,000 miles except for about a year it was not available :thmup:
Did you mean 15w40? Big difference there...
Been liked: 106 times
Re: Oil change
I use shell rotella T4 15w 40. Been using it for 20 plus years on my voyagers.
Stew (Mon Mar 18, 2024 2:24 pm)
Been liked: 249 times
Re: Oil change
If you want the best... Royal Purple, full synthetic (more expensive).
Otherwise, Shell Rotella T6 Synthetic, 15W-40. I ran 5W-40 in my Voyager, but it started having false-neutral shifts in multiple gears. When I went back to 15W-40, my transmission settled down. I assume it was the thinner viscosity which caused the transmission issues. Don't know, but they did go away, so I will hang my hat on that, for my personal motorcycle. :wnk2: Cheers!
GrandpaDenny (Mon Mar 18, 2024 9:22 pm)
Re: Oil change
Conrad wrote: Mon Mar 18, 2024 12:07 pm
No,I just went out to my garage and double checked, :hmm: the bottle says T6 5W 40 and I have seen no negative issues with it :thmup:
I am not saying you should run it,I have been happy with it ,but there are certainly other oils that are perfectly suitable for those bikes.
The VXII does not put the heat stress in the oil my GS1100GK did,as my heat gun often showed the head at 345Fand pan at 240+ on the GS
Re: Oil change
Most full synthetic oils have a much higher thermal breakdown temperature than conventional oils. That is one of the advantages of using full synthetic oils. It does vary, quite a lot, from brand to brand, however.
Back in the 1970's, to the 1980's, conventional motor oils broke down into carbon sludge as air-cooled motorcycle engines tended to run at the oil's thermal limit! My 1979 Honda constantly ran at 250 F, in the oil pan, as measured by a gauge I installed, which was the thermal limit of the conventional oils at that time (I installed an Oil Cooler radiator, and it dropped to 210 F). I added SeaFoam, to the engine oil, ran it, idling five minutes, to allow the oil to reach 180 F. That is the temperature detergent oil begins to suspend crud within it. This allowed the filter to catch much of the loosened sludge. The oil changed from caramel color, to coal black. I changed the oil and filter, immediately. I repeated the process, 6,000 miles later: the oil never darkened, at all. This was in 2011, I think.
Modern conventional detergent oils are superb at cleaning engines, keeping them clean, and their thermal breakdown temperatures are higher! Modern engine oils, all brands and types, are a marvel of modern engineering.
I treat every engine with SeaFoam in the crankcase, once only. After that, I let the oil do its job. Most of the modern engines (1996+) I've treated, never darkened their oil... Lawnmowers, and other small engines using non-detergent oils, are another matter, though. Cheers!
:gig:
ted1r
1
Has liked: 100 times
Been liked: 38 times
Re: Oil change
Post by ted1r »
Hi guys I put Motul 3000 in my 1200 ,top oil in my opinion
Ted
Re: Oil change
ted1r wrote: Fri Mar 22, 2024 5:20 pm Hi guys I put Motul 3000 in my 1200 ,top oil in my opinion
Ted
Nothing wrong with that oil either :woohoo:
ted1r (Wed Mar 27, 2024 6:09 pm)
