compressor guage light goes on in neutral and off in gear
NightRider1
1
Current bike(s): 2000 kawasaki W650 1984 kawasaki Voyager zn1300
Post by NightRider1 »
compressor light comes on in neutral and off in gear and sometimes stays on it works when light is on is there something connected to the neutral that has to do with the compressor light
Has liked: 244 times
Been liked: 634 times
Re: compressor guage light goes on in neutral and off in gear
Compressor light?
Me Again
Been liked: 286 times
Post by Me Again »
Actually, that sounds correct since the pump only works in neutral
(1300 strikes again)
NightRider1
1
did not know the pump only works in neutral but the light used to stay on and now only on in neutral any ideas
Me Again
Post by Me Again »
Most lighting issues I have fund come down to dirty/corroded connectors.
Took me about a week to track down a corroded inline fuse when my dash went out last year (lights worked but screen was blank).
NightRider1
1
ok Thankyou I'll look around
Van Voyager
Has liked: 52 times
Been liked: 44 times
Post by Van Voyager »
NightRider1 wrote: Mon Aug 26, 2024 3:11 pm did not know the pump only works in neutral but the light used to stay on and now only on in neutral any ideas
The light should only come on (and the pump work) when you're in neutral (unless they changed that behaviour with 87 & 88 models - if you happen to have one of those). If it didn't work like that in the past, then somebody changed something (which wouldn't be a bad mod IMHO, as it would be handy to be able to adjust pressure while on the move).
