Rear speaker rubber mounts
- Stormryder
- Current bike(s): 2002 Kawasaki Voyager XII
Good morning Gentlemen, I have a 2002 Voyager. After spending the day on the bike yesterday I was putting something in my trunk and discovered that I have a broken speaker mount. The rubber part separated from the metal plate that attaches to the luggage rack. The rubber split, the plate still has rubber on it. So is there an adhesive I could use to glue it back together that could be recommended or is just replacing it the correct fix? If replacement is needed do any of you have a mount in good shape available? Thank you gentlemen.
Stormryder
West Michigan
____________________________
2002 Voyager XII
Past rides
09 HD Electra Glide
07 Suzuki C50T
81 Yamaha Seca 750
75 Goldwing
72+74 Sportsters
83 Wide Glide
75 Kaw 500 triple
72 Suzuki TS 125
West Michigan
2002 Voyager XII
Past rides
09 HD Electra Glide
07 Suzuki C50T
81 Yamaha Seca 750
75 Goldwing
72+74 Sportsters
83 Wide Glide
75 Kaw 500 triple
72 Suzuki TS 125
Re: Rear speaker rubber mounts
Years ago I had the same issue. I ended up making a permanent replacement for those mounts using items I found at a local Home Depot. That being said, getting back to your problem, you might try good old contact cement. Make sure both sides of the item have glue on them, after applying let it tack up about 5 min. then press the sides together. let sit for an hour and it should stay glued indefinitely.
- Gator Mike
2002 Honda 750 ACE
https://www.amervoyassoc.org/techtipsXI ... rgency_Fix_" onclick="window.open(this.href);return false;
click on or cut an paste the link above and it will take you to tech tips. This is another fix to the problem..............Gator Mike
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
- Tom(North Alabama)
- Current bike(s): 2002 Voyager II
2002 BMW k1200LTE - sold - Location: Madison, Alabama
i have purchased the mounts from Bike Bandit in the past. don't know if they still have them
'02 Voyager XII
'08 Concours 14 - sold
'02 BMW K1200LTE
'02 BMW K1200LTE
- Stormryder
Thank you Gentlemen, I'm trying gluing it back together with some industrial adhesive. I'm gonna let it sit a couple days in my vise and then check it out. I might also order new ones from Bike Bandit and just replace them all. Thanks again.
Stormryder
West Michigan
2002 Voyager XII
Past rides
09 HD Electra Glide
07 Suzuki C50T
81 Yamaha Seca 750
75 Goldwing
72+74 Sportsters
83 Wide Glide
75 Kaw 500 triple
72 Suzuki TS 125
West Michigan
2002 Voyager XII
Past rides
09 HD Electra Glide
07 Suzuki C50T
81 Yamaha Seca 750
75 Goldwing
72+74 Sportsters
83 Wide Glide
75 Kaw 500 triple
72 Suzuki TS 125
- Has liked: 88 times
- Been liked: 153 times
Stormryder, for what it's worth I glued mine about 5 years ago and they're still holding.
