Rear lights
- odgreen
- Current bike(s): 1993 Voyager XII
1994 Voyager XII
1989 HD FLHS - Location: Daleville, AL
Rear lights
Just discovered that the rear running lights have stopped working on the trunk and lower fender. Is there a fuse or know pinch point that I can check. Not getting any voltage at all back there with the bike running, I still have brake light and turn signals. Thanks Ed
Re: Rear lights
Should be easy to visualize the fuses under the faux tank. If you cant find a blown fuse check grounds of the bulbs. Once of course you confirm that the bulbs themselves are not burnt.
- odgreen
1994 Voyager XII
Re: Rear lights
Thank you Mr Jensee, I have just located the faulty repair that someone had made before I got the bike. Problem solved and now I have all the rear lights burning bright
Re: Rear lights
Most of the time when lights particularly the brake lights stop working, it is either a corrosion problem at the bulb base or a fuse or as you found some hack job on the wires under the tank. I am glad you found it. Electrical problems are probably the number one complaint most new owners of previously owned Voyagers have. Never feel intimidated to ask questions on here. Somebody before you has most likely experienced the same problem. Enjoy your Voyager, I do.
