Radio looses memories a lot of the time.
- Current bike(s): 2002 kawasaki voyager xii
- Has liked: 9 times
My radio looses memorie a lot of the time. It seems sometimes it won’t when I turn off for a short ime, yet sometimes it will after a short time. I think accaussionaly it will keep memorie a few times, then the next time it will loose th memorie the first time. Any help would be appreciated.
Re: Radio looses memories a lot of the time.
Memory power comes from the far left fuse, a 3 amp, most problems stem from a poor connection at the ten pin connector. One has to keep that free from corrosion. Try just unplugging and connecting several time to scrap away the corrosion and make a good electrical connection. Do check the fuse however.
Gene Kap
Gene Kap
3amp is in the fuse box, 2 glass fuse's above headlamp, 1 fuse on the amp.electriccruiser wrote: ↑Tue Jul 28, 2020 11:35 am Is that behind the headlight, the ten pin connector?
ten pin - follow fuse box harness to left side
