Here are the accessories I have found so far. The first 47 all start with part number K53002-
K53002-001 Front Spoiler, Vintage Red
-002 Trunk Rack, Chrome
-003 Rear Mudflap, lighted
-004 Trunk Rails, Lower, Chrome
-005 Saddlebag Rails, Lower, Chrome
-006 Trunk Trim, Upper, Chrome
-007 Light, Upper Trunk Rail
-008 Saddlebag Trim, Upper, Chrome
-009 Lights (2), Saddlebag Upper Trim
-010 Saddlebag Lid Trim, Chrome
-011 Exhaust Extension, (set), Chrome
-012 Front Fender Trim, lighted
-013 Driving Light Mount, Chrome
-014 Lighted Spoiler, Beige
-015 Driver Floorboards
-016 Passenger Footrest, BRDS
-017 Auxiliary Backup Light
-018 Drivers Backrest, MKLND
-019 RH Trunk Pouch
-020 Caliper Cover Set, Chrome
-021 Lighted Spoiler, Red
-022 Front Fork Lights, Chrome
-023 Fairing Vent Accents, Chrome
-024 Saddlebag and Fairing Accents, Chrome
-025 Rear Floorboard Covers, Chrome
-026 Front Fender Extension, Chrome
-027 Rear Fender Extension, Chrome
-028 License Plate Panel, Chrome
-029 Mirror Visors, Chrome
-030 Trunk Hump Guard, Chrome
-031 Lighted Switch Assembly
-032 Handlebar Switches, Stacked
-033 Front Speaker Accents, Chrome
-034 Clutch and Brake Levers, Chrome
-035 Fork Seal Cover
-036 Passenger Armrests
-037 Cassette Bag/Mount, Beige
-038 Rotor Covers, Chrome
-039 Windwings
-040 Splash Guards, Chrome
-041 Cassette Bag/Mount, Black
-042 Driver's Backrest, Burgundy
-043 Trunk Pouch RH, Burgundy
-044 Passenger Armrests, Burgundy
-045 Driver's Backrest, Black
-046 Trunk Pouch RH, Black
-047 Passenger Armrests, Black
40107-1069 CB Antenna
40107-1074 CB Radio Assembly
090025 Trailer Hitch, Chrome (This number seems incomplete, can anyone comment?)
Unknown number items: Cordura nylon rear speaker covers, Black
Trunk rack zip top storage bag, Beige
Trunk rack zip top storage bag, Black
I have only listed accessories available from Kawasaki dealers as OEM options. There are/were many other supplied items such as Baker Air Wings, Marvella passenger footrests etc. etc.
If anyone can add to this please do so and we can then have a definitive list,
thanks,
OEM Accessories
- Has liked: 117 times
OEM Accessories
- Nails (Wed Mar 24, 2021 6:52 pm) • cranky (Wed Mar 24, 2021 7:04 pm) • cushman eagle (Sat Apr 03, 2021 2:28 pm) • 1ReddRyder (Sat Sep 04, 2021 9:17 pm)
- Rating: 44.44%
Re: OEM Accessories
I think this should start a sticky. Hopefully, folks will add the aftermarket.
- 1ReddRyder (Sat Sep 04, 2021 9:17 pm)
- Current bike(s): 2001 Kawasaki Voyager XII (low mile gem !)
Re: OEM Accessories
And these should all still be readily available, right ??
Thanks for the post. Lots of time researching by someone !!
Re: OEM Accessories
Addendum to post:
As some of you know there are several of the accessories which have an "letter" suffix after the 3 digit section of the part number.
For example the original K53002-006 was the trombone slide, closed end style of the upper trunk trim rail and the K53002-006A was the later open 2 rail end style.
The same applied to the saddlebag upper trim rails as the later open end had the last 3 digit part number of 008A .
The driver floorboards had a revision or 2 as the latest incarnation had the peg style of toe and heel shifter and had the last 3 digits of -015B .
The caliper cover must have had a revision because the installation sheet in the Tech Center has the last 3 digits of 020A .
The fork leg lights also had a revision or two as the latest part number was 022B . I can attest to one change that being the mounting bracket had a change as I have 2 styles of it.
And Lastly, the part number for the Black passenger armrests was 047A . I'm not sure what the change was here.
If anyone can comment on the above in greater detail than I have, and post details of the "A" revisions in the case of the B numbers, please do so in the interest of clarification of the differences.
Regards,
Regards,
- cushman eagle (Sat Apr 03, 2021 9:25 pm) • 1ReddRyder (Sat Sep 04, 2021 9:18 pm)
Re: OEM Accessories
One particular accessory which should have had an "A" or "B" suffix to denote an update but did not get an update as far as I can discern was the K 53002-033, Front Speaker Accents, Chrome.
When I tried to fit them on the black plastic '87 and later speaker covers, which have the metal mesh, the raised edge of the mesh required the accent cover to be carefully filed on all 4 sides in order to lay flat against the plastic. It wasn't much but it should not have been necessary.
Then one day I tried another un-modified accent cover on a 1986 speaker cover, which is just the molded plastic with plastic grill slats and no metal mesh raised above the line of the plastic framing, and lo and behold the accent cover fitted perfectly flat against the plastic speaker cover.
So far as I can find there wasn't any revised version of the accent cover which allowed for the larger dimensions of the later speaker covers which had the metal mesh.
I may be incorrect in this and perhaps a later, revised with the last 3 digits having an "A" or "B" suffix, part was introduced. If so and you can elaborate on the part number please do so.
Re: OEM Accessories ADDENDUM
For all you OEM optional accessories connoisseurs I have found 5 additional items:
all items have the K53010- first number and #-101 should be noted as being for the 6 cylinder ZN1300
K53010-101 Soft tail bag RED, ZN1300
-102 Floppy soft tail bag BEIGE
-103 Rear speaker cover BEIGE
-104A Floppy soft tail bag BLACK
-105A Rear speaker cover BLACK
Note the tail bags mount on the trunk racks.
- 1ReddRyder (Sat Sep 04, 2021 9:20 pm)
