The engine/transmission seem like Kawasaki tuned them to not need to utilize throttle blips on downshifting. The engine doesn't seem to gain RPM quickly enough. Is this true, or is it just me not knowing my bike well enough yet? Will I cause damage if I don't blip the throttle, but instead let the clutch out slowly after a downshift? That sounds like something my Dad would say might burn up the clutch
Currently, she's parked on her center stand until I get the oil/oil filter changed a couple of times. I'm planning to use a method I found on the forum, where you put your 3 quarts 22 ounces of oil in, plus 6 ounces of Seafoam, then idle until everything comes up to temperature and drain it all out. Fresh oil and filter in afterwards, of course. Previous owner put about 500 miles on the oil change, but then the bike sat for about 2-3 years. They did put the progressive springs in the front forks, and possibly the rears(I may be misremembering), but they put a set of D404 tires on so there is some occasional wobble. I learned not to use the front brake if I was still turning slightly into a parking spot, the 404 seemed to flex the sidewalls out and I got to test the crash bars - they made getting the bike upright again a lot easier.
Looking forward to going on cruises with my brother, and camping excursions with my best friend. I don't think my wife will ever climb on the back seat, but if I can someday convince her we could do some moto camping - the XII seems like the perfect bike for it.
I also found some AVA roster books in the trunk, dated 2010 and 2011. The bike came from Villisca, Iowa, and was bought at Hornung Cycle in Hubbard, Iowa. Maybe a previous owner was active on the forums? Looking forward to getting to know you all!
