Brake,Oil and fuel light ??
Winddancer
2002 Honda Shadow A.C.E
2002 Honda VTX 1300
2000 1100 V-Star Classic
1983 Honda V-65 Magna
Post by Winddancer »
Hi ..
Does anyone know why my Brake, Oil and Fuel lights all light up at once..
it has been happening for the past couple days when I am braking..
it doesnt happen everytime I brake, but more of a harder brake..
as a side note, and minor rant..
I tried to search but no luck, and I really do not like the search engine here.. because Brake, oil,fuel,light are too common and it leaves them out, leaving me no words to search.. seems silly to me..but anyway..
Thanks for any help...
Re: Brake,Oil and fuel light ??
I have never heard of that , but I would put a rubber band on the front brk lever to keep the brake on and then start wiggling the wires to try and duplicate the condition. That's all I got , sorry....
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
disconect the oil pressure switch and see if the problem goes away. i have seen this happen if the switch is damaged or shorted out.......
debron
Post by debron »
Winddancer wrote:as a side note, and minor rant..
I tried to search but no luck, and I really do not like the search engine here....
I would have to agree with you, searching for something is hit and miss, and when you "hit" you often get hundreds of irrelevant posts. Unfortunately, the search function is part of the forum software, over which we have no control. I'm a member of three other forums that use the same forum software (phpBB) and searching there is the same. . . :-(
suzib6sw
Tourer
Tourer
Post by suzib6sw »
I , Of course, bow to Carl's experience and I took a look at the Circuit diagram..
It seems a little odd that the oil light uses a blue/red wire as does the brake switches and lights..
Has it always done this since you had it or has it just started?
Pete
1986 Voyager XII
??????????? Well Chuck, its been over two weeks. We all want to know what you found. I know from past battery low conditions that the batt light will come on when braking , but the oil lamp never came on at the same time. Keep us posted.
Winddancer
2002 Honda VTX 1300
Sorry,
Been out on a road trip and just got back last night..
Thank you Carl for the info..
It did still happen occasionally on the trip,
I will go out now and try to disconnect the wire and see if it still happens..
Winddancer
2002 Honda VTX 1300
By disconecting the wire, the lights did go away..
but it also caused the lights to totaly go away, as in,
when you turn the key on the fuel,brake,oil light no longer light..
not sure if I like this...
Furchin
Post by Furchin »
It sounds like you left the switch disconnected. I think Carl meant for you to try this to verify if the switch is shorted or damaged. Probably have to install a new switch and in the mean time hook the old one back up to regain your lost lights.
'96 Kawasaki Voyager
Lucasind
and a bunch of parts !
Has liked: 201 times
Been liked: 72 times
Post by Lucasind »
....furchin hit this nail on the head..... not to mention , the cost of the oil sender switch is very minimal !
Winddancer
2002 Honda VTX 1300
hahaha.. :bat:
A shining example of a brain dead moment..
