cross over tube
- Lance McCaw
cross over tube
Got all my O-rings for the crossover tube behind radiator today and all other O-rings. Gonna fix that antifreeze leak on my 1986 1200 Saturday. Wish me luck. Also got my RAM mount for my GPS.
- Current bike(s): 78 Yamaha XS 1100
81 Yamaha XJ650
88 Kawasaki Voyager XII - Location: Sioux Falls, SD
Re: cross over tube
Good luck! Finally tracked down my leak a couple days ago. Just the lower radiator hose.
- Gator Mike
2002 Honda 750 ACE
Re: cross over tube
Be carefull removing the pipe. Soak it down the night before then pry it off working from one side to another. The pipe is a little thin and you can damage it by "beating up on it". If you work slowly you shouldn't have any problems. Best of luck...........Gator Mike
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
- bikerking.biz
Re: cross over tube
The same goes for re-installing the cross over. It is kind of thin aluminum and you will need to lube the O-rings before installation. Then, snug it down evenly at each attachment point and be careful you don't have the O-rings move from the mounting groove or "fold" which can cause a leak.
Biker King
http://www.bikerking.biz
- Lance McCaw
Re: cross over tube
Thanks you guys for all the tips. I also heard from Carl about this. I will let you know my out come after Saturday.
- suzib6sw
- Tourer
Re: cross over tube
If you happen to pinch any of the new o rings, (its possible to do even with all the precautions), you can find an alternative (one or two in a multiple pack) from Autozone..
They were in a pack of Viton O rings.. Light brown in color..
Expensive way of doing it, but got me out of a corner when I pinched mine..
Pete
Pete
Pete
1986 Voyager XII
1986 Voyager XII
- Chris near Kansas City
Re: cross over tube
I run softsoap (liquid hand soap) around the inside of the ports on the engine as well as around the o-rings on the manifold.
Chris
Chris
- Bruce in OK
- Current bike(s): '01 VXII
'06 Vespa GTS 250
'02 Honda Elite 80
Re: cross over tube
Back in my technical school day, we were trained to use oil in areas where petroleum base fluids came into contact. Where coolant type fluids would come in contact, we used Joe's Hand Soap (the plain, white kind).
Bruce in OK
- Lance McCaw
Re: cross over tube
Well everything went very good. I did not break anything. Took me about 6 hours. Thanks for all the tips everybody suggested.
- Lucasind
- 12
- Has liked: 203 times
- Been liked: 72 times
Re: cross over tube
....Bruce,....I had the same shop teacher !Bruce in OK wrote:Back in my technical school day, we were trained to use oil in areas where petroleum base fluids came into contact. Where coolant type fluids would come in contact, we used Joe's Hand Soap (the plain, white kind).
- Current bike(s): 94 voyager 1200
Re: cross over tube o ring
Where can I get a new 0-ring for the crossover tube on my front shocks on a 94 voyager. Shop says we can't get these anymore? Front end is shaking
- vxiirider
- Tourer
- Has liked: 97 times
- Been liked: 34 times
Re: cross over tube
Our resident Voyager guru, Carl Leo <voyagerparts@bellsouth.net>
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
Charlotte, Michigan
