dunlop elite 3 cupping
- Current bike(s): 2001 kawasaki voyager 1200
Just removed the rear wheel as i'm going to change the rotor and tire. My question is ... why has my rear tire cupped. The drive side is worst than the right side. I have almost 40,000 kms and i still lots of rubber except were the cupping is occurring. Any idea what is going on. As usual.. thanks
jean-pierre
ps. there is more than 1/16 difference
jean-pierre
- Has liked: 893 times
- Been liked: 315 times
Re: dunlop elite 3 cupping
The crown of the road,at least where I live, means the bike is not perpendicular to the road.With the bike straight up,the road is leaning slightly to the right for water drainage.This means the tire is carrying more of the weight on its left side, wearing it out faster.
- bikerking.biz
Most cupping problems are related to not enough air in the tires. A minimum of 40 lbs. seem to work best, but some use a few more depending on weight. Bad wheel or swing arm bearing (which also might need adjusted in the case of swing arm bearing) may also contribute to this.
Biker King
http://www.bikerking.biz
Thanks. I forgot about the crown of the road. I normaly ride with 36 lbs. I'll up that to 40. Thanks again
jean-pierre
jean-pierre
- Littlebeaver
- Current bike(s): 1999 Voyager 1200, 1981 Honda Goldwing Interstate 1100
- Highway Rider
- Webmaster
- Been liked: 40 times
Check this site out. http://www.rattlebars.com/tirewear/index.html" onclick="window.open(this.href);return false;. it tall about tire ware
Wow... Thank you for that link. I'll be passing that on to others. Upped the pressures to #36 and #40 and we will see how it goes. Yes i am using dyna beads . Thanks again
- chevyman1
- Board Member
- Been liked: 16 times
I run 40 psi front and 43 psi rear and I am getting much better tire ware
I keep my tires at 36 lbs front and 40 lbs rear. I have progressives front and rear and I believe that the increased harshness of the ride would only get worse if the tires were any harder. As it is I can feel every imperfection in the road and we have plenty in Louisiana.
- chevyman1
- Board Member
I swapped out my Progressive front with Race tech and that improved the ride a lot
