replacement u-joints
Has liked: 117 times
Hello;
has anyone used the replacement universal joint sold by atvworks.com under their part # XUJ702?
They list it as useable on the ZG1200 throughout the model years.
Thanks,
Re: replacement u-joints
triton28 wrote:Hello;
Thanks,
I have used a replacement u-joint from a larger 4wheeler Kawasaki, purchased it from Carl and I have a post with the number I believe. I would have to look but its been about 23K miles on it so far. It measured up exactly to what the old one was right down to the casting number/letter. I may have the part number out in the shop as I document things as I do PM on the bike. It was pricy at 100.00 and didn't come with new clips. But its was new and that's what I wanted. It can be replaced without the use of hammer and with a just an ARBOR press, with a split collar made up. I may still have them. Took about 2 hours my first replacement, that time is from when I had the shaft out in my hand. I had went first with one from another site listed as a replacement with a grease fitting in it. Close but no cigar and much weaker because its cross is drilled thru. and about .015 away from being an exact match. And I believe it was not exact in the cap diameter also. The company took it back and after reviewing what I had documented on measurements took it off of their site as a replacement, or so they said. When I got the one from Carl it all went together much quicker. So if you can't find a good used shaft assm. all is not lost. Gene Kap
PN / ( 49050 1002 -spider ) is the part number from Kawasaki Prairie atv
check out post named Noise/Vibration page 2 for photos of the one listed by atvworks
A Quote from that post:
(" However I have been told that an OEM u-joint listed for the Kaw. Prairie 400 atv part # 49050-1002 listed on the microfiche as a "SPIDER" IS the same part and has been used in the Vulcan 1500/1600/ and the 1200 ", )
If you go that route, and you see it has grease, Do Not Add any more grease, it will not press together properly and PUSH the new seal out of the needle cup.
Gene;
thank you for the info. I had R&R"d mine last year due to a slow rotation in one direction. After cleaning and inspecting the mating surfaces, I did sparingly grease it with Honda Moly grease and it seems to be holding up OK. But, one always has to keep an eye on a part which has exhibited an irregularity.
Thanks again,
Dave Taylor
There is a drive shaft on Ebay right now for a good price.
I'd go after this myself but I have 2 on the shelf
:thmup:
http://www.ebay.com/itm/1988-Kawasaki-Z ... 70&vxp=mtr
Highway Rider
1978 KZ650 D1 SR
Has liked: 162 times
Been liked: 40 times
Post by Highway Rider »
XUJ702 Aftermarket U-Joint Replaces KAW 49050-1002
Details
http://www.atvworks.com/products.asp?cat=29&pg=3" onclick="window.open(this.href);return false;
Universal Joint for Kawasaki rear drive shaft.
Includes clips & Grease fitting
See details for placement location diagram.
Dimensions:
Cap 22mm, Cap-Cap 51.5mm,Grove to Grove 34mm.
Replaces Kaw 49050-1002 & 49050-1075
Fits:
KVF300 99-02 Rear Shaft (LL 4)
KVF400 2X4 98-02 Rear Shaft (AA 1,2)
Mule 610 4X4 05-10 (all) Front and Rear Drive Shaft (DD 3,4,5,6)
Mule 1000 B1 1988 Rear Axle Shaft (KK 7,10)
Mule 2510 Diesel A1-A2 00-02 Propeller Shaft (KK 4,5,6)
Mule 2510 A6 2000 Propeller Shaft (KK 4,5,6)
Mule 3010 03-08 Propeller Shaft (KK 4,5,6)
Mule 4010 09-10 Propeller Shaft (KK 4,5,6)
Teryx 750 08-09 Front Drive Shaft (DD 3,4)
ZG1200 Voyager 86-03
Price: $29.95
Thank you all for the info.
