Muffler Clamp
- randallar
Muffler Clamp
Well I started removing the rear tire, needed to loosen the muffler clamps to get the exhaust down far enough. Of course I broke the bolt on the clamp. The covers were no picnic either but I got the clamp off. My question: part number is 92037-1228, there is a clamp on ebay for a ZN1300 with the same part number, same part? I would think it is, just want to make sure.
- richardb, austin
Re: Muffler Clamp
Do a google search for that exact pn & see if it comes back to more than one bike. I'll bet that it's the exact same - unless ebay seller typo-ed one or the other. If all that is broken is the actual bolt, I'd think you could replace that with a Home Depot metric bolt.
richardb, austin
__________________
__________________
- randallar
Re: Muffler Clamp
Yes it came back as the same clamp. The bolt is really in there and I don't have heat to get it out. Just buy another one.
- Wahrsuul
Re: Muffler Clamp
I had to cut the clamps off my bike. A PO had ground the bolts so far down and bent the clamps so much, I couldn't get them off any other way.
