air shocks
Randy
Current bike(s): 2003 Kawasaki Voyager xii
air shocks
Post by Randy »
correct air pressure front shocks 2003 voyager xii
rck2545
Current bike(s): 1990 Voyager XII
Re: air shocks
Post by rck2545 »
I always ran 7psi before I switched to progressive springs. If I remember right the book says up to 10psi :thk:
It's all about the RIDE!!!!!!!!!!!
Randy
Re: air shocks
Post by Randy »
Thanks
rck2545
Re: air shocks
Post by rck2545 »
I'm sure you probably know this but just in case use a air shock pump not an air hose or you will probably blow out your seals.
bikerking.biz
1970 Honda CL 350
Re: air shocks
Post by bikerking.biz »
If 10 or even 15 lbs (too much according to Kaw at 15, but I've done that for a while) does not do it and you still bottom or is too soft, it is time for Progressive springs. I assume you still have stock springs, and they really don't last all that long or do the best job by any means.
Biker King
http://www.bikerking.biz
voyager55
Current bike(s): 2003 1200
Re: air shocks
Post by voyager55 »
I'd get progressive springs. Better ride & cheap, easy to install to. Then you can ride without air in the forks
http://www.abbikeboard.com/jeff/spring/spring.html" onclick="window.open(this.href);return false;
