rear air suspension compresser
Mike R
Current bike(s): 1986 kawasaki voyager xii
Post by Mike R »
Has anyone added a pump for the rear suspension ?
Voyager xxii
Looking forward to meeting new friends
Larry in Arkansas
Has liked: 2 times
Been liked: 6 times
Re: rear air suspension compresser
Post by Larry in Arkansas »
I added a compressor some years ago and it has worked well. You can adjust your air pressure on the fly for load and road conditions.
Mike R
Post by Mike R »
Do you remember the name of the compressor ?
Voyager xxii
Larry in Arkansas
Has liked: 2 times
Been liked: 6 times
I used this compressor.
http://www.ebay.com/itm/THOMAS-115ADC56 ... 25a7925558" onclick="window.open(this.href);return false;
I only paid about $12 each for them several years ago. I used Parker quick connects and installed a check valve and in line regulator.
The adjustment are made using a micro 3 way switch installed in the headset cover that activates a 2 position 4 way valve.
I have a 1" air gauge mounted where the rear air fill valve used to be. I left all the original connections so if I had a failure, I could reconnect OE connections by removing the right fairing.
Mike R
Post by Mike R »
Thanks streetster have a good one.
Voyager xxii
voyager55
Current bike(s): 2003 1200
Post by voyager55 »
Get progressive spring shocks & forget about air adjustments etc.
You won't believe the improvement in ride over the stock shocks
mucho cheaper than a compressor outfit to I think....
Larry in Arkansas
Has liked: 2 times
Been liked: 6 times
Recall that his original question was if anyone had installed a rear air suspension compressor? Not if it was more expensive or if it was the best option or what someones opinion was. I answered his question.
I'm sure the original question was answered but this IS an opinion section.
