Water Pump Leak
lockwoodjohn
Water Pump Leak
Post by lockwoodjohn »
Hi everyone, I emailed Carl Leo about the kits to replace the water pump oil seal. My '95 Voyager developed a oil leak left side , around the water pump, I am sure from reading the posts here I will be removing the pump and replacing the oil seal. I have a Service manual and did a lot of reading about doing the job. It will be another new experience for me. ANY ADVICE will be greatly appreciated. Thank you all in advance!! I will also be doing the coolant manafold O rings also. They are starting to weep . kill two birds with one stone. ( I hope)
lockwoodjohn - John Kinney
Rick near Kansas city
Current bike(s): 2003 VOYAGER XII
Re: Water Pump Leak
Post by Rick near Kansas city »
check http://www.abbikeboard.com/forum/viewto ... water+pump" onclick="window.open(this.href);return false;
lockwoodjohn
Re: Water Pump Leak
Rick,
Thank You for your advice. The artical is a big help.
John
starrider
2013 Can AM Spyder RTL
1976 Time Out Camper
Been liked: 5 times
Re: Water Pump Leak
Post by starrider »
Had a similar problem with my 2002 when I first got it. The water pump bearings were so worn, the impeller hit the inner housing each revolution. Broke the lower mounting bolt. Started leaking oil as the housing moved each revolution. Funny it never leaked a drop of coolant or heard any noise. Replaced the entire pump.
Re: Water Pump Leak
Many of the Voyagers fixes are online and you can do a google search, try this:
http://tinyurl.com/hbq9y4b
Has liked: 893 times
Been liked: 315 times
Re: Water Pump Leak
While you are that far into it,do a careful check of all the coolant hoses. :corn:
