won't start
mikey
Current bike(s): 2003 kaw voyager 1200
won't start
Post by mikey »
hey guys, i know this is a voyager forum but i need help. i have a 2003 kawasaki nomad, 1500 fi. with 20,100 miles will not start. she is getting gas, spark, i put a new battery in today and new plugs. it turns over real strong and sounds like it wants to start but won't. the last time i went for a ride was dec 12 2015 about a month ago,came home and parked her in the garage she was running fine. any ideas what might be wrong?? :tho:
Relics
Current bike(s): 1988 Kawasaki Voyager
Re: won't start
Post by Relics »
I know this may sound too simple but be sure to check handlebar stop switch.
Re: won't start
If it is getting gas, spark and starter is turning over then there is no reason it should not start unless like listed above the kill switch is set to off. Some bikes it kills all the power and some it will only kill the ignition. Check your air cleaner to make sure something is not blocking the air input.
Re: won't start
Check the spark plugs make sure they are clean and gaped properly.
:thmup:
KISSfanJoe
1984 Honda V65 Magna
2002 Victory V92
1984 Kawasaki KZ 1100 LTD
Re: won't start
Post by KISSfanJoe »
I'm with Chevyman... Check the gap on them and make sure it is set to factory specs. I sold a bike that wouldn't start and the new owner adjusted the gaps... The bike ran like a champ after that.
Also, Nomads rock! I have a 2005 myself that has a batwing fairing on it, and hard bags. I love riding it!
mikey
Re: won't start
Post by mikey »
all is good now,i found the problem.must of gotten some bad gas. we found some water in the gas. thanks for your help :clap: :bravo:
lockwoodjohn
Re: won't start
Post by lockwoodjohn »
Mikey,
Now that it is running treat your bike to some Sea Foam, About every 3rd tank. One ounce to a gallon of gas. It will help keep water from causing any more problems and keep the fuel system clean. I don't know if your bike has one, But ya might want to think about changing the fuel filter.
lockwoodjohn,John Kinney
mikey
Re: won't start
Post by mikey »
i want to thank everyone for there help. we have a good bunch of riders on here :woohoo: :thmup: :thanks:
