Trunk Tips
JHD
'09 FLHT Police
'03 RE Bullet 500
'77 XS 360-2D
Trunk Tips
Post by JHD »
My trunk is a bear to slide back and forth. I completely disassembled cleaned and put it back together. Still doesn't slide back and forth easy. What gives, any tips? I'm afraid one of these times I'm going to push it off the center stand trying to push it back.
Been liked: 249 times
Re: Trunk Tips
Get some white lithium grease in a spray can (safe on plastics), then lubricate the slides, and the release lever's bearings, making sure to work it in by moving things around a bit. It should free it up fairly well. Cheers!
the2knights
Has liked: 32 times
Been liked: 8 times
Re: Trunk Tips
Post by the2knights »
Make sure you did not over tighten the trunk. I actually did that on purpose on mine since I just leave it in the rear position all the time anyways!
Re: Trunk Tips
Check the slide disk- White Disc- Not sure of the Tech name- for cracks, flat spots & wear.
I replaced mine few years ago. Cheap part if needed
Check to tightness securing the trunk. You might have it to tight so it doesn't slide properly
JHD
'09 FLHT Police
'03 RE Bullet 500
'77 XS 360-2D
Re: Trunk Tips
Post by JHD »
OK guys, thanks for the replies. I will try loosening things a bit,
