Hose routing for overflow tanks
Hillbilly
4
Current bike(s): 98 Voyager xii
2021 versys
99 KLR650
Has liked: 27 times
Post by Hillbilly »
Hello everyone, so I'm finally going back the other way with the Voyager and putting it back together. The problem is that I had to take time away from it and can't remember where the hoses go for the radiator reservoir or the smaller overflow tank I didn't take any pictures and the service manual didn't seem to have a good picture of them either.
I was hoping someone could look at there bike or give me information on where they route. Thanks a million times for your help ,this forum is a very valuable source of information for me. :thanks:
Has liked: 245 times
Been liked: 634 times
Re: Hose routing for overflow tanks
Pretty sure there's just an overflow tank, which some folks call a reservoir. Thus, the hose that runs from near the radiator cap to that tank (under the left side cover). It's the only small-diameter coolant line on the bike, save the drain from the overflow tank to past the swing arm.
Note that it's easy to pinch this line with other parts, especially if you also fuss with the fuel pump. My bike came pinched like that. Not good.
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
Been liked: 58 times
Post by Chris Cochran »
Since mine is partially dis-assembled right now I can get some pics for you but it'll take a few hours, possibly. I have things to do this morning.
Ok, I've got pics from the radiator cap all the way down. But I have errands to run so I'll download when I can.
These users liked Chris Cochran's post:
Hillbilly (Sat Jul 23, 2022 12:57 pm)
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
Here you go: Image
So, from the radiator cap area it goes off to the right and then runs along the top frame.
Sorry, you have to tilt your head to get proper orientation.
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
Then it will tuck in behind the air box here.
Now you see where it comes out. This hose attaches to the bottom of the overflow tank. Finally, this shorter hose attaches to the top of the overflow tank and dumps overboard.
And once again, please tilt your head...... irritating.
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
Lastly, the "small" overflow tank routing:
This hose routes over the top of the bigger tank, through the notch seen in the pic, and then attaches to the air box.
If you click on the photos, they come up bigger and right-side up.
Chris Cochran (Mon Jul 18, 2022 3:49 pm) • cushman eagle (Mon Jul 18, 2022 7:47 pm) • Hillbilly (Sat Jul 23, 2022 12:57 pm)
Rating: 33.33%
Has liked: 512 times
Been liked: 455 times
The "small tank" is called the surge tank. It collects the crud that accumulates in the bottom of the lower airbox, such as rainwater, oil blow-by, and general ick. The drain hose for it goes pretty much straight down and exits the left side by the side stand. Good idea to drain it occasionally.
Hillbilly
4
2021 versys
99 KLR650
Has liked: 27 times
Post by Hillbilly »
Thanks a ton you guys. I've been so busy at work, it's been weeks since I've been able to work on it and the same goes for thanking you for your help.
These users liked Hillbilly's post:
Chris Cochran (Sat Jul 23, 2022 8:13 pm)
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
I just discovered that I lied to you a bit. The notch in the radiator overflow tank has that notch in it BUT it's for the top hose coming out of the overflow tank that drains out on the ground and NOT for the hose coming from the surge tank to go through.
That hose actually goes underneath the larger, overflow tank.
Damned if I know what I was thinking.
