HF Hidden Gem air mixture screw tool
BackTrackBug
Current bike(s): 2002 Kawasaki Voyager XII 1200cc
Has liked: 18 times
Been liked: 5 times
Post by BackTrackBug »
$2.99. I checked and it does fit into all four mixture screws on bottom of the bowls. May have to take chrome guard off alternator for #1 carb. But the ratchet clicks/gear is small enough that you can get atleast 2 to 3 clicks on all the screws. And if you want even more clearance it looks like you can grind the 1/4 inch socket drive off the back without effecting the operation of it. Harbor Freights screwdriver aisle, $2.99.
These users liked BackTrackBug's post:
SgtSlag (Mon May 01, 2023 1:53 pm) • Nails (Mon May 01, 2023 5:00 pm) • GrandpaDenny (Tue May 02, 2023 12:06 pm)
Rating: 33.33%
Been liked: 250 times
Re: HF Hidden Gem air mixture screw tool
Could have used this post a few years ago... There are times when such a screw driver is the only tool that will work. Need to visit my local HF. Thanks for sharing. :thmup: Cheers!
Has liked: 243 times
Been liked: 633 times
I still recommend etching the carb body and using a dentist mirror to monitor that the screw actually turns.
BackTrackBug
Has liked: 18 times
Been liked: 5 times
Yup. I used my engraver and etched a small line where the screw bottoms out.I can see how easy it would be to become totally clueless if your one turn out or 4 quickly. That is a good idea Nails. And I have a dental mirror on my " things I need" list for the XII.
