A little help for an old fart
ppb0861
Post by ppb0861 »
I took my rear caliper off today but still attached to the hose. It was loaded with gunk and that is why I think it was locking up when backing up. Anyway I spit shined all parts and started to reassemble it. Problem is there is a thin metal piece mounted in the caliper that the brake pads ride on and goes under the piston. I can't remember how it goes back in. I just love getting OLD !!
Any help I would appreciate. Even a picture here or to ppb0861@gmail.com
Thanks ! :bat:
Lucasind
and a bunch of parts !
Has liked: 203 times
Been liked: 72 times
Re: A little help for an old fart
Post by Lucasind »
...Go to any post by "MrJensee" on this forum, and click on the manual link, ...there you will see a exploded view of the brakes.....and all else, :-D
debron
Post by debron »
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
To: the old fart from older farter!
From the manual in the above post the only good photo of it is on PG 11-3 . If you pushed it accross the page the direction toward the caliper & put it in the top or closed part of the caliper the way they are both pictured that is the way it goes. Hint: don't over think it, it can only go in one way and fit right, UNLESS I was doing it!!!
ole farts half to stick together! ooooo!!! erase that thought!!! :-O
good luck ..
ppb0861
Post by ppb0861 »
Thanks to all for the help. :bowdn:
Most motorcycle brake calipers are nearly the same. You might refer to this video, it might help with reassembly. I have found that using a medium size 6" C clamp works best for pushing the piston back in without damaging it.
